A wee bit more to it than this. The center console needs to come up, which simply means the ashtray/heated seat trim needs to be popped off, then the console lifted up and off. Traction Control plug needs to be unplugged from switch for the console to come completely off. The shift bezel may need to be taken off, or at least lifted up for room. The bezel pulls straight up and unsnaps from it's holders. You should then be able to twist the bulb housing counterclockwise, pull out, and replace bulb.
