Here Are Pics 04 Chin Lip Installed
kwazy
who dey
Let Me Know What You Think
Looks good, glad you did that since I was thinking about doing it myself. What happened by the wheel well? did it just not line up?
Still Have To Sand Down The Ends With The 03 And Up Its Stock Valance Is Different On The Ends It Dips Down So A Lot Of Trim And Cutting BUT THE WHOLE THING LOOKS A LOT BETTER THAN I THOUGHT IT WOULD REALLY MAKES THE FRONT LOOK DIFFER FROM OTHERS
Sounds like a pain in the a$$! Definitely looks good! I'll be waiting to see pics after its all trimmed up.
How exactly sis you mount that up? I can see part of the lower valence above the lip. I thought that it was going to be mounted between the lower valence and the bottom of the bumper.
Looks good. Too bad you need that stock lower valence to hold the splash pans/wheel well liners in place. It would look a lot better without that in the way.
I need to get a hold of some of that chrome trim like you have on the front bumper... :shifty:
you have to leave that on because of the wheel well splash gaurds the ends will be cleaned up and you wont even tell that its two parts
Is there any way to see how it is mounted from underneath you car? But I will say that it does make the car look so much more sporty!
youll get a ticket before it falls off if you know how to install things like this you can make it nice and solid
Looks very nice!
Kwazy, can you please post a picture showing the lip from the side? That perspective would give an idea of how far out the lip is.
Do the ends need to be trimmed on the pre 03 cars as well? PLEASE take some pics of the under side push pins I assume you drilled the holes in the existing valance. What size bit did you use?
