midi_junkie
How do i remove the whole thing.. all i want to do is change the high beams bulbs but its like jammed so tight i cant w/o removing it. How do i remove it?
its easy?
So the lightbulb doesn't just twist out? It does on my 2002 LS. You just pull off the light socket (it's clipped onto the bulb), and then twist the bulb about 90 degrees and pull it out.
Is this the same for a HID car?
I have a crack in my assembly and want to replace it.
(I will be honest, I kind of pussied out when I saw the warning High voltage, take to dealer signs)
Girlyman!![]()
Yes, its the same with the HID. Mine has HIDs. I replaced the high beams, and I'm still alive.
