How Much
CT Swagger
CONNECTICUT
How much should it cost me to replace the 2 valve cover gaskets and all the intake gaskets on a 2000 V6???
dealer wants over $900.. nobody else wants to do the job for me..
My dealer wanted $1200 for my 2000 V8. I bought the gaskets for about $200 and did it myself. These cars are very labor intensive. It took me about 8 hours to do the valve cover gaskets, coils, and plugs. On most cars that's a 2-3 hour job max. If you're comfortable with working on your ride do it yourself, if not, rob a bank. LSes aren't cheap to repair.
I honestly did not know anybody else was making gaskets for the LS. Felpro is a good brand, but Lincoln re-engineered the replacement gaskets to avoid the original problem. It's really up to you. I can't give knowledgeable advice on that. Anybody with a V6 please help him on this. I'm not gonna mess him up with bad advice.
What is the actual problem, are the valve covers leaking on your V6? If not, I'd leave them as they are. On my first V6, I had to do a coil replacement on the right bank, you know, the passenger side. It was the weekend and I didn't have access to anything beside a new coil. I didn't see anything leaking on the valve covers, so I didn't loosen them. On the intake, I cleaned the original gaskets with electronic parts cleaner (degreasing fast evaporating CRC spray) and found the original gaskets to be in fantastic shape for an engine with 102K miles. They were literally like new. Looking at the part that does the actual sealing, it is like infused silicone bead, and that all cleaned like new. When I reinstalled, the seal was tight. No leaks, and 2 mpgs gained to boot. When I ripped it down, the intake bolts were all pretty loose, compared to the proper torque value. If the silicone is all in good shape, that is all there is on the intake gaskets, the rest of the gasket is a plastic spacer and has no wear surface to go bad. As I said, if the valve covers are not leaking outside or in the spark plug wells, there is not much of a need to take them apart. I had no idea they were that expensive, either. Wow.
Yeah its leaking and the plugs are soaked.. yeah I think im goin to just go with the redisigned oem gaskets..
what I cant figure out is why there are 4 different intake gaskets on the repair and replace sheet the dealer gave me to get fixed???? and almost 8hrs to do the work at the dealer seems alittle long for a certified tech
2- valve cover gaskets-$37.96
2- Intake gaskets- $45.24
1- Intake gasket- $19.35
1- Intake gasket- $19.05
6- Spark plugs- $58.56
8 hours is a long time at the dealer for a trained mechanic. However, the going rate for labor is $75-$100 an hour at most American car dealers. (As opposed to European, much higher). they also charge by how long the job SHOULD take on average. I used to work at a Pontiac dealer in high school. A car would come in and the Service Manager would quote the customer a set price based on the job being say 5 hours of labor. In reality the mechanic did in 2 hours and the customer got screwed. Just an example. Anyway, good luck with your ride.
what the BEST spark plugs for more power on a ls 2001 V8 an the best coils?????
I did this job a few weeks ago and the only gaskets I replaced were the inner valve cover gaskets. You can buy the inner and the outer separately from the dealer. The outer gaskets looked good and I added some sealant at the corners around the cams. The intake gasket looked to be in good shape and I reused it.
how bout these labor costs...
R+R valve cover gaskets= 2.7hrs
R+R intake gaskets= 3hrs
R+R spark plugs= 2.1hrs
over 2hrs to put in spark plugs thats werid no?
OEM spark plugs is best for they were used to develop and tune the LS.
Coils you don't have much choice. It isn't so much the coil as the oil leak that destroys the coil, fix the valve cover gasket with the newer designed ones and it should not be such a problem.
Does anyone know where I can get these new designed gaskets for my 00v8 besides the dealer.
