A whistle in my ear, 93 Mark.
davidm
Broken Arrow
I have a constant whistle from the drivers side. Starts at 55-60, cannot pin point it.
Have placed masking tape on different places, even the top left corner of the rear window, replaced the upper dor seal, adjusted the door jam inward slightly, (have not messed with the hinges) stuck some weather stripping around the door also.
Its the simple things that are hard to find. Running out of ideas.
David
Try this. Drive with windows down, then put the drivers side up. After its up, the passenger side.
My driver's side does NOT go all the way up if there is pressure in the cabin.
+1 for unity's idea, if that still dont fix it, try taping ALL around the door edge, then try around the window seal, usually its one of them making the noise
Will try the window sequence, and then the tape around the door edges.
I noticed this car does have tight seals, you can feel the air resistance when closing the door.
David
Found the source of the whistle. It is the drivers side mirror. I placed different sizes of balsa wood around the housing with masking tape. Narrowed it down to the the gap between the housing and the chrome window trim. Wedged a piece of rubber fuel line in the gap. All is good.
DavidM
Try smoke with a straw and force it around the seals have someone look from the outside when your inside
whoa mannnnnnnnnnnnnnn, cough cough (if only i had the smilies from chicagovelocity) :bong:
good to hear you found the prob :D
I also use this on hose lines to check for vac leaks it worked great to find the leak on my egr tube or to make sure your fan air is pulling the right way. If only i was 16 again and driving around town in a camaro with my friends man get rid of that stuff there is a cop behind us
Well I dont use the hose technique, I use a stick of incense. Just point and watch the smoke. And since there is not TOO much smoke, it works really well.
As for the OTHER smoke, well....
For me it a pack a day of the cowboy killers but a big no on the other stuff
DavidM
Geez, I just noticed the exact same thing happening to my 93. I'll check out the housing later.
Thanks for posting!
