tri-valleyracin
Will 96-98 stock cobra exhaust manifolds fit on a 1994 mark VIII so i can get rid of my cats? i was goin to buy frpp but if the cobra ones fit i think there relativaly the same.
i just cant just spending 700 on kooks.
also you would have problems with your EGR tube which is a B!TCH to try to bend.
Ditto on the EGR, I have no EGR, my friends have no EGR and you should not too!
Friends don't let friends have EGR!
You need an EGR to pass emissions. There is a visual check for it if your part of the country requires a smog test. Besides it's there for a reason, it helps to reduce (nox) which will occur without a properly working EGR valve. The EGR valve actually reduces the temperature of the cylinder heads.
I bet that you guys without catylitic converters and emissions equiptment must have some really stinky exhaust. You can make a car fast while still being emissions friendly.
how about the newer (06~ish) model ranger the 4 cyl has a egr block off plate, and poss the 3.0 too
(cali spec did but we all know they dont count)
Some vehicles do not require an EGR or AIR PUMP because they meet the clean air standards, Others have them for a reason. I just really don't see the reason to disconnect everything and chop your cats and EGR off? You might see very minimal gains (IF ANY) You might even lose low end torque without the cats. Besides do you want your car to stink? It will without the cats.
But it's your car so you can do what you want!![]()
