For the record, I wouldn't buy a Wal-Mart synthetic ever, I just could not trust it.
Check the label next time you are in there for the specs. And price. You might be surprised.
But cant one think that this is marketing garbage as well?
My main purpose for useing RP is that you can keep it for 3 times the amount of changes that some people go by.
It meets a standard yes, it all must meet a standard but its only worth what you pay for it and that is the minimum standard required, so yes if I wanted the minimum I would use it but I want better so Ill pay for it. That is the whole reason why some decide to use RP because you get the 75$-90$ a case worth of cash out of it.
is it good to put royal purple oil in my 2002 lincoln ls i have 55,000 miles on it?
LOL. The experts are right..reading comprehension in America is at an all time low.
I clearly said above "exceeds Lincolns (actually Fords) minimum requirements for oil".
As far as "marketing hype". Viscosity ratings and ASE/API aren't marketing lables. They are government specifications. with regards to the specifications..from the label from a quart of SuperTech 5w-30:
"Exceeds API SM/CF, ILSAC GF-4, ACEA A1-02 and previous API gasoline engine classifications including SL, SJ, SH, and ILSAC GF-3."
Now your homework assignment: Find out the oil spec requirements for the LS, then compare to the above..and compare to the factory recommended Motorcraft synthetic blend.
Then bash...from an educated perspective.
Actually, NONE of that was cut and paste. Want to use google to verify? ;-)
And what..no basis to substantiate your argument I take it? No scientific data? No documented facts disputing the SM rating and the fact that it exceeds Fords requirements?
Didnt think so.![]()
*flex*
Enjoy the labor day weekend!
