Factory Tech valve body separator plate
I was perusing thru the super coupe performance website, and came across this item. Has anyone tried this, or know someone who has? I see it comes with the new 1-2 accum. and 2-3 accum. Looks like it comes with a different 1-2 spring also.
http://supercoupeperformance.com/partBrowser.aspx?partId=228
sounds like they drilled a stock plate and added accum parts,
no too bad i guess,atleast you will still have your old stock plate if you want to return to stock shifting,but if you dont ever want to go back to stock ,i say save $70+ and drill yours
Once you drill it out you will never want to return to the stock. Just drill it !!
I got it in my car, works great, itll chirp second gear everytime. but the first month or 2 i had it in ( i guess it was still rbeaking in a little bit) it would chirp into second at like 3k or higher rpms. which is still cool with me ;)
I take it you installed the spring thats included in the kit? I would prolly just check my springs and accum. to make sure I have the updated pieces. I'm not looking to chirp gears, I just want more positive shifts.
I had a FT separator plate. Good stuff- especially if you have a pre-98 tranny.
Is that everything you need for the JMod except filter and fluid? Im thinking it may be less trouble than piecing a J Mod together.
