Yeah, there are commecrial sprays you can use, and many have had success with Lysol.
If I was doing it on the LS, the easiest access to an intake would be removing the Cabin air filter that is under the right front cowling against the firewall. Just remove teh filter and spray away while the system is running full blast and NOT recirculating.
Good Luck,
Jim Henderson
