I HATE "LIFETIME" anything unless it is warranty coverage.
Lifetime is just long enough that the manufacturer figures no one can blame them for a component failure. Now if the mfg guarantees the engine and tranny for life, then I have no squawk on lifetime fluids or anything else. But interestingly For has decreased their warranty time on the Lincolns, so maybe things aren't as lifetime as they want you to believe.
ALL components and fluids wear out and have an "optimum" service life and then there is the maxiumum or lifetime service life at which point the fluid has failed. I do NOT like lifetime service intervals or even extended intervals. My experience with ALL extended or lifetime service intervals is that things start to look pretty yucky a some point. Ask people how many of their lifetime lubed ball joints and bearings have failed?
My persoanl LS case in point, my lifetime lubed tranny failed at 15K, diagnosis was fluid failure, duh. Lifetime lubed wheel bearing failed at 40K, I am guessing lube failure don't know, dealer didn't say.
Other example, 100K mile spark plugs. BS in my opinion. I had 100K plugs on my previous car. It started to run rough at 80K , pulled the plugs, they looked like those posters you see on garage walls showing totally worn out plug pictures, electrodes were more worn out than any other plug I have ever pulled on my regulalary serviced engines.
A second issue which I have not had enough miles yet, but I have heard horror stories on 100K plug changes on cars with aluminum heads. Cadillac Northstars are notorious for the plug "rusting" into the head and stripping the head when removed at 100K. Many independent garages refuse to change them and send you to Cadillac. They don't want the blame when they strip the threads. I bet this is also a problem with the LS. Mine were changed at 40K due to coil issues so it will be awhile before I need to worry about this.
100K Antifreeze?? Starts to look yucky at about 50K in my previous car and my LS. The fluids gather contaminants over time and start to deposit them in the overflow bottle. Maybe by the service manual that is OK, but just doesn't seem right. So I plan to change well before the what, 150K interval?
I use synthetic oils in all my vehicles since 1980. I occasionally did extended drains and didn't like how the oil looked even though it had not gotten to the maximum the mfg recommended. So I change my syn at the "normal" factory interval.
Most of this is my visual interpretation of what I see. I suppose you could chemically check things, they do with oil, but to me it is just better and probably safer  and cheap insurance to change fluids and some components well before their rated life, especially lifetime stuff.
Just my cranky opinion of "Lifetime" stuff.
Jim Henderson
