mikedeezy123
I got those knocks and squeaks and rattles in my front suspension the LSs are known to get when high mileage kicks in. I also have an aftermarket warranty that says it covers the following related to suspension:
FRONT/REAR SUSPENSION: Upper and lower
control arms, control arm shafts and bearings or
bushings, upper and lower ball joints, radius arm
and bushings, torsion bars and mounts or
bushings, stabilizer bars, links and bushings,
struts, strut bearing plates, spindle and spindle
support, wheel bearings, variable dampening
suspension, compressor, control module,
actuator, solenoid, height sensor, and mode
selector switch.
My question is based on the usual crap that needs to be replaced to fix these common issues (knuckle, bushings, stabilizer bar etc)....what do you think my chances are of getting all this covered? All help is appreciated.
selector switch.
