GMAN
I found some HID's for GMANjr's Mark. I hooked them up and they work fine. Today i noticed a ton of condensation inside the lights. It was unusually humid today. What do i need to do to prevent them from sweating?
Are the vents on the housings open?
you should have bought my set.
Maybe try and dunk the whole housing under water in a bath tub to see where the air leaks out, thats where the water is getting in, then dry them and do the alcohol trick.
Did you try what I recomended, because it has worked flawlessly for me.
