vertical Trenz chrome grill...where do they sell these?
Aviation
Maryland
i saw a pic of someone on here with one of those, and it looked sharp
i either want to get the regular chrome grill, or this vertical trenz one...where can i get this at? how much am i looking at?
i got a lot of chrome trim on my car, but the damn grill is black!
i need to chrome it up!
sorry for all the questions today. lol
You have a few options, the LSE grille has the chrome inlays, someone also sells the stock CHROME inserts for ur stock grille. You can also get the trenz vertical and horizontal i think those are on eBay along with the chrome inlays.
id rather buy something already prepared and just have it fit, rather then modifying but thanks
Good luck then! No one sells an all chrome grille that you won't have to modify. Even with the Trenz grilles you'll have to modify your existing grille to make it work.
yeah i found the trenz online for about 220 dollars.
the chrome inserts are probably what i saw on ebay, it like gets glued over the stock portion, dont think i want to do that if thats what it is, probably a bit cheesy
oh, i wasnt aware of that.
what do you have to modify to make it work with the trenz grille?
With the Trenz grille you have to have a 2000-2002 LS grille. Separate the bottom black waterfall from the top chrome piece. Then you install the Trenz billet grille to the upper chrome piece. This requires some drilling to make the lower part attach to the upper part. Then you mount it to the car. With the aluminum bottom part you will have to bend is slightly to fit properly. This may take quite some time. So, in all the Trenz grille is not out of the box and bolt it on your car.
I couldn't find an install guide for the Trenz grille on Lund's website. However, they are floating around here somewhere on the net.
