Low Washer Fluid/Reset Button Broke!!!
KainDTE
Largo
Well first off no matter how much Washer fluid I put it my car always says "Low Washer Fluid" And second My reset button no longer resets anything I guess I hitting it every time I got into the car took its toll... Well what do I have to do to fix these things?
Cut the wiring that goes to the connector in the washer bottle and splice the wires together. I can't remember if there were 2 or 3 wires on that connector, as I did it a while ago and no longer have the car.
or just replace the sensor its a common prob
I bought the sensor from Max a month or so ago. It was 12 bucks. Took asbout 6 minutes to change. If you take the headlight cover out from under the hood its on top of the reservoir closest to the center of the car. Its the only thing there with wires on it. Ill try to get a pic tomorrow during daylight if you would like.
Yeah if you could that would be awesome.
my low warning came on one day, filled the reservoir up, hit reset, it kept coming on everytime i started the car..........popped the hood, found the sensor, smacked it real good...........and all was good.............. ;)
serious........maybe it got stuck or something :confused:
Pics
This ones a little fuzzy but....
Pic 2
This ones better. Right behind the grille on the drivers side.
I did this today on my '94.
It looks like the 2nd gen cars are easier to do that the 1st gen if thats what your pic is of...
I couldn't get it out more than about 1/2" till it hit the bumper bar. I had to remove the bolts holding the power steering cooler so I could move it a bit for room, then three bolts that hold the washer container bracket the the bumper, as well as one up top for the neck of it, so I could 'turn' it some to pull the sensor all the way out. I also took the plastic panel that is held in with the push pins up top (the one with the doors for the lights) which is super easy, just so I could see more and do it from the top, but don't think it would be totally necessary (I was afraid of breaking the new sensor after the old one came out in two pieces!) I sprayed the new seal & sensor lip with a lil silicone lube and it slid right in... It only took about 1/2 hour-45minutes to figure it out and complete the job, and I was taking my time to see what I was doing...
Scared me for a minute after I did this and turned the car on only to see the low washer fluid warning again... then I realized it indeed was low on fluid so topped it up and I'm good to go now ;)
The pics were a gen 2, I didnt disassemble anything at all. But you have an idea where it is now. The second pic is upside down because its the only way I could wedge the camera in.
