i have 17x9 cobra wheels on my t-bird right now running 275 out back with the offset at 36, will these go right on a ls without issues? thanks.
Also wrong bolt pattern!
Yeah, if they fit that vintage T-Bird, they should fit both an LS and a Mark VIII, bolt-pattern wise. I don't know what the Mark's offset is, but it should be the same as or very close to the T-Bird's. (The LS's is 60mm, BTW.)the t-bird is a 97, will they fit on a mark 8? thanks.
I had a MarkVIII with Cobra R's that I had on my 95 Cougar, they'll fit with no issues. The LS shares the same bolt pattern with 93-98 Lincoln Mark VIII's and with the 89-97 T-bird/Cougar MN-12's also with the Rangers and Marquis and Crown Vics and Marauders I believe. The offset is different though. And you dont want to go with 9" wide b/c to me they'll stick out to much.
