Speed Rating on Tires
TorontoLS
Toronto
Does anyone know what is the recommended speed rating for Michelin Pilot MxM4 tires for a 2000 LS-8 Sport? I have to replace my tires and was asked whether they should be 96H or 95W rated....
Thanks in advance. :)
See tire rack's tire tech section here.
It will tell you all you need to know about the speed (H & W) and load (96 & 95) rating of your tires.
I doubt you need any tires rated higher than H.
well he has a sport which means it 'can' get up to around 143 (up and beyond the H tire rated range) fwiw tires i bought are z speed rated.
It all depends on what you want; Z-rated tires are generally going to have stiffer sidewalls than H-rated tires, so they're going to contribute to a slightly stiffer ride. On the plus side, they should help in the handling department, as they will flex a bit less than the H-rated tires.
In broad, general terms, H-rated tires are more for cruising, while Z-rated tires are more performance-oriented. If your car is a sport, it almost certainly came from the factory with the Z-rated tires.
Will most people be able to tell the difference between H-rated and Z-rated tires? Not if you showed them the markings on the sidewall and explained it to them.
The speed rating really isn't that big of a deal. You can run up to top speed on H-rated tires; it's just that Z-rated tires are rated for maintaining those speeds (which is something sane people do not do unless they're on the track--or on the Autobahn, which happens to miss the entire US by, oh, an ocean's width ;) ).
Thanks guys. I think I'll go with the best tire for performance. I have a lead foot and take turns fast. The LS still brings a smile to my face on onramps, etc. :)
