my ls is turning over and starting most of the time but it seems like it struggles. I have to charge my battery up once every 2 weeks since it dies. The charging system checks out okay and I have 12.8 volts on the battery. Its just starting the car seems to drain it I guess? Someone said maybe its my cold cranking amps and i should get a new battery.
So what do you guys think????
i also just took off the ground to the car and it broke the screw so i moved it over to the battery hold down. maybe i had a bad ground and it ruined the battery?
