cig lighter stopped working
hellvez
VANCOUVER
I bought a sirius radio and the front cig lighter would not work so I plugged it into the rear and it worked fine for a couple weeks then it died. any quick fixes to this? does it happen alot?
Check the tire pressure in the rear passenger tire. Once you do that, open the Driver's side door, and pop off the fuse panel cover. Check the cigarette lighter fuses. If they are good, then you have otehr issues. If they are bad, replace them.
I would have thought he would of had to rotate the tires before he could get into the fuse panel, I know I had to!!
LOL
it's allso that time again to change from winter air to summer air in all the tire's just thaught i would pass it on :p :p :p
whaaat... I was being nice. I made a legit suggestion, didn't I? :lol:
Yes you did.... it was nicer than most of your post to simple questions. I guess there is hope for everyone...:p
Eh. you only have to rotate the tires before accessing the fuse panel on the uber cool Mark VIII's. the regular marks, you don't. :lol:
Sorry Frogman I've found your error.:eek: :waving: So you are not as smart as you think.:rolleyes:
You have to rotate your tires when checking fuses under the hood and that's on all Mark VIII's. Now if you had an LS you have to use your spare tire before you install your curtains.:eek: :slam
That's right I forget the daylight savings time came early this year! Dont forget to change the air in the spare!:rolleyes:
What side of the spare should be up during Daylight savings?
Also Where do they keep the passengers side spare?
Oh by the way Hellvez we are not picking on you at least everyone but....:rolleyes: LOL....
