2006Lincoln
I’ve read some very interesting and detailed posts that covered in great detail, the most common failure of the Lincoln LS: Coils. My thread asks the question: Has anyone actually researched and tested for the root cause for these extremely common coil failures?
Most will say… just change all the coils and spark plugs together, not individually as they fail. Check for oil contamination from a leaking gasket or vacuum leaks. Some of which, are the culprit, and fix the issue. But, what if you have no oil leaks or vacuum related problems? You’ve changed all coils, spark plugs and injectors. You’ve checked ECM pulse with a noid light, resistances with a multimeter, fuel rail pressures and bleed down tests, but still experience misfire, especially when the engine reaches operating temperature?
I’ve discovered the true root cause of this issue: Engine design.
One thing that is overlooked in every thread I’ve read so far… how heat affects wiring resistance. For every 1 degree Celsius, copper wire resistance will increase 0.4% (obviously dependant on gauge). But, what gauge wiring runs to the coils/injectors on the Lincoln LS? Approximately 18ga. This smaller wire, combined with engine heat trapped under the “coil cover plate”, ultimately leads to heat-sinking and drastically increases the wires’ resistance. Thus, creating a domino effect that destroys components like the coils and injectors.
The very design of the 3.9litre coil wiring harness is at fault.
