Sorry i just recieved a email with you're new post, so far  i have replaced camshaft synchronizer,camshaft position sensor, EGR vacuum solenoid, front calipers and brakes, spark plugs and plug wires, starter, thermostat, solenoid, drivebelt, flushed the cooling system, dropped transmission pan changed the filter and did a soft flush, fixed all the codes, rebuilt all the dry rotted vapor canister lines and  vaccum hoses, installed all new carpet, degreased and washed the seats, replaced lift supports and brackets. Now ive got to pull the back inside panels off and seal off the window channels from the inside. Typical Aerostar leaks around the back windows. Everything else seems to be in great enough shape that im fixing to start driving it.  Can't wait to put it to the test and go on a long trip lol.
  As for the 93 YJ build its been put on hold for the moment. My buddy can not decide if he now wants to use the LS motor and trans out of the 2008 GMC he bought or the LS motor and trans out of a 2001 Chevy Silverado that he has owned for a while. Im trying to convince him that the 2001 Chevy LS would be a easier YJ swap electronicly and he should fix the 2008 GMC and he will have him a newer nicer truck. My buddys  son in law wrecked the 2008 GMC about 2 months ago but its not hurt that bad. A new front cap an front steering knuckle and my buddy will have a nice truck. His son in law had just put a new Jasper 5.3 LS engine in the 08, it already has the delete kit installed an comes with the diablo tuner with less than 10,000 miles on it. The 2001 Chevy is not a bad truck it has 180,000 miles on it. He's wanting to keep it as simple as we can electronicaly.
  I would like to hear you're opinion. Which engine do you think would make a better YJ swap the 08 or 01? Also would you take the body off the Jeep to do the swap? I believe it would be easier that way.
