Re: forscan. At least on my gen 1, forscan could only change a very limited number of things. They were all modifiable in the V8's message center anyway. Pretty disappointing considering I first toyed with a 2nd gen fusion that had a couple hundred modifiable lines with a dozen changes tailored to my liking. I don't have a solution for you otherwise. I looked some time ago and didn't find any easy solutions in the wiring, although I don't remember the details. It might be easiest to add a switch (ignition-on I'd prefer) to send power straight to the fog relay. You'd have to check the polarity of the switched signal as this car loves negative-switched circuits
			North America has a law against having more than four light beams from the front of the car at the same time.
I can't promise the law is for this reason, but generally you don't want the short-distance wide-beam of a fog light increasing the overall light in your eyes, reducing your night vision through pupil constriction, while using the far-throwing high beams. Typical fog lights don't help you over 40mph because by time it lights something, its too late - if you wouldn't drive with just your fogs at the given speed, they don't have enough throw to help. Meanwhile, low beams should be more than adequate on their own below 40mph or so. It drives me insane seeing people using high beams to assault a flat 25mph residential area with streetlights. HOWEVER, headlight fanatics do acknowledge high+fog operation as "bambi mode" which is useful for hilly, curvy driving with a lot of deer/wildlife in the area where a floodlight would be best. Please understand its not useful on the highway
			You've got to be kidding me.  That would still only be 4 lights even if a fog light bypass could be done.
I thought it was alternator load related.
OP wants the fogs to stay on regardless of the highs. Seems like the bypass you're talking about is just getting the fogs to come on without pulling the switch out, based on your pictures. If OP made their request work and was driving with the lows and fogs, turning on the highs would only add to the lights: lows, highs, fogs = 6
			One of my other big lighting peeves is the people that turn their hazard lights on when it is raining.  Follow the law, turn your headlights on instead.
and I swear it's always a gray car. At least DRLs are required now, although DRLs combined with illuminated dashes seems to have increased the number of cars driving at night without headlights.
			That may be true, but I have been I downpours so heavy that the hazards show up better than the tails. That doesn't happen too often
And yes... headlights on during rain... always.
I wish we'd adapt and understand rear fog lights here. I tend to see Audi SUVs these days with their rear fogs unknowingly powered and just about never in fog/mist conditions. VW and Volvo wagons used to be the common [mis]users. They're the ones that look like funny brake lights - sometimes one on the driver side, sometimes a pair. They're brake-brightness without defeating the actual brake or turn signal light functions.
