2005 Lincoln LS V8
Hi Folks, hope thigs are well;
Background: Original LS Expert Mechanic is no longer employed at local shop:
Problem: When installing the new radiator apparently a lot of Transmission Fluid was lost when disconnecting the transmission lines.
Which resulted in overfilling the transmission and causing my pump seal to start leaking again!
The shop apologized and offered to have it fixed at his recommended local area Transmission Shop;
However, I preferred to have it fixed at the shop (70 Miles Away) I had the Seal replaced in back in 2016 when I inherited the LS after it had been sitting for two years prior.
Fast forward: I went by that original Shop this weekend and they have new owners and don't do a lot of Transmission repair work and could not look at the car realistically until around July or August. (Also, the mechanic I talked to kept saying the LS was front Wheel Drive; Nah, I know I need to go somewhere else!)
Was wondering if anyone in the Los Angeles County Area has had any transmission work done.
I can tow a 100+ Miles to a new shop.
Thanks...
Thanks...
