Reviving my old LS but can't find a etc connector
my_oak
Lexington
So I'm reviving my old car, a 2005 LS 3.9L that's sat for about a year and a half. Now I'm working to get it going as the only drivable car I'd have, so I've really been dug in trying to solve the codes. I've ran into a brick wall though and can't seem to find any connector
that'd work for my etc motor*. It's obviously burnt up and it's throwing voltage high and voltage low codes, does anyone know where to find one of these? I found this on ebay that looks exactly like it except for maybe the locking pin but the seller says it wouldn't fit and there's 0 left
here's a picture of my burnt up plug
if anyone could give me either a model number or a link to one that'd work I'd be incredibly grateful since this has all been a bit of a headache for me and I'd love to get this car running like it used to.
*cheers for the correction joegr
I think that many different Fords used the same TP sensor (so would be the same connector) on the early ETC trucks.
Thanks much for posting the part number!
That's a big help to others searching for this problem.
This comes up on rockauto.com but does not look like your photo. Do you have the correct part name that is needing a new connector?
This comes up on rockauto.com but does not look like your photo. Do you have the correct part name that is needing a new connector?...
Yes, the picture he shows looks like the two pin connector to the ECT throttle body motor, not the TPS (throttle position sensor). I think that one is three or four pins. They are on opposite sides of the throttle body.
Makes more sense as I don't see a throttle position sensor handling enough current to melt anything.
Yep that's the connector there, the etc motor is the issue. Vehicle runs a bit rough with it unplugged but with it it's stuck in closed loop when I idle and open loop when I accelerate. It's stuck in limited rpm, limited idle, and etc failsafe mode. All the codes rounded back to electrical issues from the 'Throttle Actuator Control Module' and an issue with cylinder 1 circuit that I think I've weeded out to the connector being shorted right at the bend. I'm going to be soldering them both with new connectors within the week so I guess I'll see.
