Brian Mifsud
I started this project before Covid.. and relied upon memory which isn't working to put things back..  The wiring harness for the fuel injectors is routed behind the intake manifold.  I pulled the manifold to replace 100% of all cooling lines and hardware (car is 2004 Thunderbird).  Manifold went back in fine along with new gasket.  There is a ground strap attached to the plastic mounting bracket which attaches hardness to top rear of Manifold.  The strap is about 8" long from connector to connector.  One connector (really an  eyelet or flat with hole in it ) has a 1/2" long copper prong extending 90 degrees from the eyelets' end. There is a stud extending out of the firewall very close to this strap, and makes sense that one end is meant to be attached here.  Where does the other end attach?  If COULD reach the Cosmetic Engine Cover which is bolted to studs coming out of the passenger side head.  Just don't see any tell tale marks in the paint of the bracket.
