doubledidgit
I searched everywhere for front and rear complete strut assemblies. All I can find are the struts replacements. What can anyone recommend for new strut assemblies.
			I forgot to mention I have a 2000 Lincoln LS V-8.I searched everywhere for front and rear complete strut assemblies. All I can find are the struts replacements. What can anyone recommend for new strut assemblies.
Where'd you find those at? ThanksThanks for the info. I want to replace the springs, struts, and all the components. I did some research and found Strutmaster makes an easy strut with everything assembled front and rear for 750.00. Not cheap but they are the only ones who make them. Also made in the USA. Ordered front and rears today.
(Srtutmasters} in North Carolina.
Yes.or is the entire coil over strut junk?
the upper mounts are literally all the same whitebox stuff. unless you get the genuine ones with the orange foamYes.
Not sure what you mean by "the springs are bowed". Do you mean bent at the bottom tail?
Most parts for the shock are still source-able. The upper mounts, (with boot), can be found on Rock Auto from manufacturers such as Moog and a couple others. Again... don't buy the cheapest.
					www.lincolnvscadillac.com
				And far as I know on the LS they are rebranded monore which is pure junk.(Srtutmasters} in North Carolina.
Wish that I had a compressor, couldn't find one anywhere so I used ratchet straps for the rears and an E350 van with a receiver hitch on the front for the fronts, sketchy but effective, lolstop being afraid of the compressor and do it the right way.
strut masters is charging you an extra $500 to put together some trash
To argue with a person who has renounced the use of reason is like administering medicine to the dead. THOMAS PAINE: Founding Father Quote.
