so im trying to do these rear lower control arm bushings (the one at the knuckle) and ive so far got one side pressed out, and the new one pressed *most* of the way in. Ive got it pressed to where the outer case stops, which is where my press is pushing against, but the only adapter i can find that will fit around the rubber, does not fit into the hole in the control arm, so it stops before its all the way in. any of you guys that have tackled this job, what did you use, or where did you get the adapter that fit inside that hole in the control arm, but also was big enough to fit around the rubber of the bushing? ive read tons of posts on here talking about it, but nobody ever says exactly what they used, or what kit it came out of exactly, or where they got it.
