Brian Mifsud
My son's 1996 58K mile Mark VIII sat a long time apparently in a garage.  When we bought it, the whole car was/is cosmetically PERFECT inside and out.  It has the Mystic Style Paint which turns from Tan to Purple.
Anyhow, front airbags were bad from sitting so long, and didn't want to put in the crap Chinese units, so installed the T-bird Struts... goodbye Lincoln great ride, but the car was back to rolling. Then an inexperienced driver not recognizing a rising temp gauge, led to a series of overheats. A shop found hydrocarbons in coolant and quoted $4600+ to fix it admitting it was a conservative quote not knowing if block/head were warped (engine rebuild basically).
Son has since bought a Camry and I'm stuck with gorgeous but immobile Mark VIII with all systems in great shape except failed head gasket and possibly warped head/Block?
I have not torn it down yet as I'm working on my Daily Driver, a 2004 T-bird replacing the cooling system's plastics to prevent overheat/head gasket failure.
If I pull head to replace gasket, I will check for flatness after cleaning up surfaces. Is there any proven method to keep any sanding crap out of cylinders as I progressively sand the deck flat again using a precision long bar and wet/dry paper? I'm thinking positioning crank so there's a large enough gap between deck and piston top to allow me to fill the void with Playdoh or something that will catch any grit from sanding.
I'd use a granite surface plate with sand paper glued down to treat the heads, but the block is the tricky one. If necessary, I'll pull the pistons to make sure everything gets cleaned properly, but am open to proven methods if someone knows they work.....
