bluefish
The drivers side inner door handle on my 02 Lincoln LS "broke" the other day. Now when you pull it, the door doesn't open. Have to roll down the window and open the door from the outside handle. I took off the door panel and looked around. I see there is a cable going to the door lock and another that appears to go to the outside door handle but no 3rd cable going to the inner door handle.
Q1: Is there a cable? Or does the inner door handle use another mechanism?
Q2: Does the whole inner door handle need to be replaced or is there a way to fix it?
Thanks!
Thanks!
