Self test code 5041???
00LincLS
Columbia
I ran the self test on the ac system and got a 5041 code. When I read the details of the code it didn’t make any sense to me. Can someone clear this up? I was running the test to see what code popped since the system is only pushing out hot air.
I assume that everything else is okay? Speedometer working and no ABS warning light?
The code is saying that the DATC isn't receiving vehicle speed information from the ABS module. This in itself would not be why you are getting hot air. Is it non-cooled air, or is it very hot heated air?
It’s both. Sometimes it’s non-cooled air then the longer it runs it’s very hot air. Thought it could be low on refrigerant or the DCCV is going bad.
