2005 v8 radiator up or down
White LS
Zephyrhills
Will be replacing a leaking radiator in my 2005 v8, is it better to remove the radiator from the to or the bottom?
In my opinion (I've done two), easier from the bottom. Drive up on regular ramps, and there is enough room to tilt and remove/install the radiator from the bottom.
2006 Lincoln LS Workshop Manual
Thanks for your answer, I had read your post on the procedure from 2006. I have read that post a couple of times and I did not see were it said remove from the bottom.
