What type of antifreeze/coolant do you use in your LS?
We're told to use a HOAT like Motorcraft Gold or Zerex G-05 for the LS. I'm wondering if the HOAT coolant is what is causing the plastics to not last in the LS? My Mark VIII uses the conventional green as that is what is recommended and I've never had any overheating or plastic parts problem.
It was my understanding that the 3 different types of antifreeze are used because of what parts such as a radiator is made out of like copper vs aluminum, etc. I understand that the OAT & HOAT types are longer lasting also. I know at least a couple people here are or were not using the HOAT type in their LS, even saw a post from Joe a while back saying he does/did not use it. "Prestone pre-mixed has worked well enough for me." (below)
engine coolant
I'm about to replace my leaking degas and other plastic coolant parts, and I'm thinking about using the old school green coolant instead of the Motorcraft Gold/Zerex G-05.
My question is will I do any damage to any of the metal parts while possibly trying to help the plastic parts not break down as quickly. (If that is in fact the problem) Any knowledge or thoughts on this subject would be much appreciated.
engine coolant
