Hey, guys!
Been reading on the boards here for a while now, but I haven't come across the answer to my latest question: how is compatibility for electronics from the '04 to '05 LS and vice versa?
Long story short, I'm Frankensteining my old '05 LS and my new (ironically older) '04 so I can put away some money and do a little more reading before I get into reading down the heads (external coolant leak on one of the gaskets and compression loss in cylinder 6). So the bulk of my question is: I would like to keep my recently cut keys and my FOB, so I know that I need to swap the PCM, theft module, and cluster at a minimum - but is there anything else I have to move over for the car to run right? Maybe the BCM? Both are 3.9s, I've pulled the full option code lists, and I don't see anything that's too different between them (cosmetics mainly, and the new one doesn't have back-up alarms).
Any advice you guys would be greatly appreciated, and thanks for all the helpful stuff you guys have posted on the past!
