COP Electrical Connectors
nghtshd88
New Jersey
Where can I buy these? Or what is the part #? Not getting a click on two and want to make sure they arent sliding back.
Go to a u-pull salvage yard, they'll likely give them to you. clip them off and either splice them in, or for a lot better install back the pins out of your connectors and replace with the new ones. This is pretty easy once you get the hang of it.
I would be willing to bet he's talking about what's often called a 'zip tie'. Nylon strand with a toothed hole in one end that the other end is fed into to create a loop---used to hold things together.
KS
Ford had three different p/n's over the years for the primary connector on the older 2-pin COP's, they were;
1995-1999
3U2Z-14S411-SMA
Motorcraft #WPT-579
2000-2008 (maybe still used in some applications to 2016)
3U2Z-14S411-SLB
Motorcraft # WPT-986
2009-2016
BU2Z-14S411-FA
Motorcraft #WPT-1133
Best (tightest) fit with silver plated terminals - finally solved the intermittent connection issues.
These were also used as connectors on other engine sensors.
