Tony_1992
Hey guys, I just replaced the spark plug of my Lincoln LS V8 3.9L. And after that I drove the car on the highway for a test drive. Everything works fine. No Engine warning, rpm in normal range, same or even better fuel performance(17.5mpg in city and 26mpg on highway). Only one little problem that haunts me now.
When the car is in idle, I tried to floor the pedal to the end but the maximum rpm that I can get was about 3000rpm, no matter in P or N mode. This phenomenon disappears in D4 and D5 mode, in which I can easily get 5000+ rpm when accelerating.
Is that normal and the same to your car? Or, is this a huge problem?
Also, I was a little worried about the potential missing fire problem before replacing spark plug. How to eliminate the possibility of that?
Thank you!
Thank you!
