So the old turn signal switch in my 2006 is bad and I ordered a new one. I ordered a Motorcraft SW6013 which is the turn signal switch without automatic wipers.
Now on the old one the wiper control was just one big plastic knob at the end. Push it in for a wipe or hold for wipe and clean. Rotate up for intermittent or all the way up for slow and fast constant wipers.
The new one is completely different layout. Push button at end of arm for wipe and clean. One rotary dial that lets you either gets 1 wipe, intermittent, or the two constant speeds. Then a second rotary dial to set the intermittent interval.
I'm assuming it's just an updated configuration since the old style probably had a high failure rate. I do know that the intermittent wipers never worked right on mine unless you went 2-3 clicks up and that's not something limited to just the LS.
