sunroof
PT.LINCOLN
kingsville
Have a 1998 Lincoln Mark viii. LSC.
my sunroof is up on the driver side and will not retract back. Need some hlp getting this fix asap.
There is a thin metal bar that extends from one side to the other @ the rear of the opening. I'd first check to see of it is in place (1 screw each side). If it's not it very well could've came undone and jammed something up preventing it from moving correctly.
Oem or aftermarket?
Pic?
Great will check that out. Thx. And it's all org...how would I put pictures up on here?
On the bottom right of the reply box you'll see a Go Advanced icon, click and at the next page there will be a icon that says click to upload photo. Upload and select the file and it should insert it into your reply. Or use http://postimage.org/ and copy/paste the Hotlink for Forums (1) option into your reply.
