06 Lincoln ls egr/map sensor problem
garcia82
Warren
Ok im going to do a new forum because my first one made no sensé so Ill statut from the beginning my engine light came on one the code was p0401 for a map sensor manifold abbsolute presure sensor i was told to change the egr son i did now im getting a p0405 code i dont no ware the map sensor is i want to change it and see if thats the problem
It's MAF sensor Mass Air Flow. It should be on the air intake snout near the air filter box. You need to take that off-brand EGR valve back and get a Ford part. don-ohio (:^)
Well Don, I really should defer to your oblivious wisdom in yet another thread, but I just can't let this guy be so mislead...
It is in fact a MAP sensor. Manifold Absolute Pressure. It has nothing at all to do with the MAF. The MAP is one of the sensors inside the EGR valve assembly. The OP has already been told that his Aftermarket EGR assembly is likely responsible for the P0405 code, as this has been reported here before and solved by replacing with the OEM EGR valve assembly.
P0401 - Exhaust Gas Recirculation "A" Flow Insufficient Detected
P0405 - Exhaust Gas Recirculation Sensor "A" Circuit Low
How does anyone get MAF out of this?
So this model doesn't have a MAF? Interesting. Glad you straightened it out,but you don't have to be condescending Joe. don-ohio (:^)
Yes, of course the LS has a MAF. Why do you think a car can't have a MAF and a MAP? One can't replace the other. I would imagine that most cars have both now.
(And I wouldn't be condescending if you hadn't sprayed so much nonsense all over so many threads recently.)
Ok then i guess Ill get a new egr thank you for clearing the map sensor problem i cant get the egr valve from the parts stores onley the factory??
Does anyone know how many air line go from the egr to the intake i just got this car and am wondering because there are to that come of it that i would say definately do but this is set up with the to off egr but with one of them it has a rubber y connecter with another airline connected to it which is comeing from a sensor connected to the fuel Rail im wondering if it is set up wrong causing a bad reading
Im woundering if the vaccume lines were changed and are to small making it read there is not enough pressure
great a third thread just to cover exactly what was said in the very first response of the very first thread...
if you ever get this fixed or even need further assistance on this, please do us all a favor and do not create yet another thread, just pick one of the ones that you have already started and continue from there. that way anybody reading isn't finding 30 threads with none of them being complete. it really hurts the next guys wanting help, especially those willing to search for the answers they need themselves.
also what a surprise... another day and another post by Don telling some the wrong sh!t.
#OldSchoolFTW
You keep quiet Telco ... you lied to me ... promised me this was going to be fun ... it's not!
.... i cant get the egr valve from the parts stores onley the factory??
Local parts store most likely don't or won't carry OEM Ford/Lincoln parts, you'd have to try your local dealership (expensive) We tend to get quality parts from tascaparts.com, fordparts.com or rockauto.com
OEM Lincoln part #6R8Z-9D475-AA
http://www.tascaparts.com/lincoln/l...stem-cat/egr-system-scat/?part_name=egr-valve
It's on sale right now at Tasca for $106.35
Hope that helps (unlike some other info presented)
Perhaps you just have the wrong sort of sense of humor... I find the gibbering of idiots to be quite entertaining. The barmier the better, I always say. I think where you're going wrong is you're taking him seriously, always a mistake when dealing with the mentally infirm.
Well Im happy to say i changed my egr and know my light is off to everyone definately dont get aftermarket parts thanks Jogr problem soleved
