Yes, i know that. I did that, 8 times already.
this needs to be done AFTER the repair has been made...
the procedure itself is not a form of repair.
if you are having to do this, and you did not have to replace cooling systems parts, then there is 0% chance of fixing your car with this...
if you have to do this 8 times, you are either incapable of following simple, straight forward instructions, or (as been told) you have MAJOR cooling system failure/s
honestly, although you may not want to hear this, it may be something you need to consider...
trust me, I understand how cool an LS is (some of the time) but if you need it to get to work, and it is incapable of getting you to work, and you cant afford to fix it without working...
how long can this go on before you are fired and have no work to go to?
new luxury cars usually have expensive maintenance.  then god forbid, need non warranty covered repair tend to be insanely expensive. then you take an old luxury car, that had very low production, extremely few companies that make ANY parts for it, and is now having trouble lots of its parts will only make it prohibitively expensive...
you may actually need to sell this car and get something that is actually reliable and can at least get you from point A to point B... hell for the price of just the repair you need, you could just buy a rock solid dependable car and not even need to sell the LS. I have either for myself or friends/family bough quite a few good but ugly and not cool cars from anywhere from a few hundred dollars up to near a grand (pretty much in the range of every repair you will be needing to make that car... again... and again)
hell my trusty rusty caviler starts and runs where ever it needs to go every single time the key is turned... in 6 or so years the only money that has been put in to it (other than tires, brakes, oil and fuel) has been a $13 T stat and a $80 wheel bearing and a $100 battery.  never has it not got me to where I need to go, nor had to call for a tow, nor cost me a day at work. (unlike the LS, which on more than one occasion wanted to drive it to work and had to go back inside and switch keys because it wasn't going to get me there that day...
found a $300 honda civic for my cousin after his trans blew out in his piece of sh!t LS (that I tried to keep him from buying since no way was he about to get a good deal spending $2500 on a car that used to cost $40k+ )and he couldn't afford to fix it, after having to borrow money to fix his overheating problem, after having to sell his Xbox to get money to have to fix his windows wont stay up problem...   also that car breaking down did cost him one (at least) job.   has been driving it for three years and has not had to replace a single thing on the car.
