SC outlet tubing and Mass Airflow Sensor
OU812IC
Wi
I have the Vortech cobra mustang outlet piping. I have what I believe to be a lightning 4" OD MAF sensor. I don't see these two piece blending together to make a blow thru setup, at best the Vortech stuff is 3".
Do I make a new set of tubing 4" or do I weld the 2005 and up mustang MAF fitting and use that sensor.
From what I can find I want to have blow thru if possible. The MAF I have can easily fit the bill if I go suck thru.
I searched on the Web and here for different configurations but haven't seen quite enough detail to be decisive with parts selection. Some pictures are better than others but I would like to hear feedback on "what I wish I would have done" or "do not do".
I'm confused. Mine uses a lignting MAF in front of the radiator behind the cold air intake filter (as you call suck). With a supercharger I do no see how you could utilize it after the supercharger (as you call blow thru) ??????????
Is there a chance I can get a pic of your setup? I am struggling a bit with this part. I found d some pics but not quite enough detail for a suck through or maf on the inlet side of the SC.
This is the best I could find soon.
I like your mount way better than the Vortech one have. It would have saved me a ton of screwing around in the radiator and fan area. As you already know mine mounts about where your coil pack sits.
