thenewguy
Hey guys just bought this lovely car last week and first day it overheated on me. Ive been reading this forum non stop for the last week and see this is a common problem with the thermostat housing and the elbow part 9N499. I was hoping someone can please help me out since most these posts on the forum are missing pictures because of broken links so im a bit confused. This is my first time working on a car ever but I love to learn. So on my 2006 LS v8 with 146k miles on it Im replacing everything touching the thermostat.
Im stuck on how to go about getting the bolts for 9N499 out. Ive read either pry or cut.
My question is if i pry do i just loosen the bolts on the intake manifold only and just lift it up a bit with a pry bar? Are the only bolts I loosen number 15 in this diagram ? Do I need to replace the gasket too since im not opening all the way(#16 in the diagram)? Is there anything else I should worry about like fuel lines or anything dangerous? Really don't want to make a mistake.
If I go the cutting route do I just unscrew as much as I can cut half of the screw and unthread the rest by hand? Do I need to also disconnect anything like fuel line? Is it safe making sparks under the hood? Again this is my first time working on a car but got to learn somewhere. Sorry if my questions come across to you as obvious or dumb but this is a brand new language to me. Thanks for your time and any help is greatly appreciated!
