Hi Everyone,
I took a look today at the factory access hole in the inner fender that will grant access to the nut with an extension and a swivel joint. I also tried a regular 18mm open end wrench.
I'm also not opposed to breaking the flags on the bolts, but it looks like you still have to remove the shock to hammer on the 15mm socket for the bolt.
So I looked into the gear wrench that I found many on here talk about. They even listed links, but with the thread from 2011, they no longer worked. I found many different "gear" types and hope that those that have done this previously will provide their thoughts on which would work best. long, stubby, S or C shaped etc. See below.
