Well, apparently the pictures below are showing the ac charge port and those 2 lines going into that fitting On either side are Part of the coolant system I believe that is attached to the ac Compressor . at first I thought my leaking steering fluid was coming from there but it must be leaking somewhere above that and dripping down through there . I have found the culprit!!! The first image shows exactly where the leak is coming from. It turns out that the steering fluid is slowly leaking and trickling out through that electrical connector connected to the steering pump at the bottom of the pump. I recall another thread where I believe this issue is discussed so I will conduct a search to see what this piece is and how to repair/replace it. I am assuming this piece is some type of pressure sensor that somehow has a seal that has deteriorated and is now allowing steering fluid to seep through into the electrical connector and run down the harness. I hope there is a write up or a general diy on this issue but I will take more pics as I work this problem just in case someone else has to tackle this job as well. My Lincoln LS is an 02 v8 by the way. image on this post shows
[iurl="http://www.lincolnvscadillac.com/forum/attachment.php?attachmentid=828462284&d=1379475490&d=1379475490"]
[/iurl][iurl="http://www.lincolnvscadillac.com/forum/attachment.php?attachmentid=828462285&d=1379475494&d=1379475494"]
[/iurl][iurl="http://www.lincolnvscadillac.com/forum/attachment.php?attachmentid=828462286&d=1379475498&d=1379475498"]
[/iurl]
