I’ve done rebuild a front suspension, Lower Arm, inner/ outer tie rod, Stabilizer Link, Strut rod bushing – Moog K8680 (front to lower arm). Front to Frame bushing frame was fine. After i Installed them, I did the alignment at Firestone. After 200miles, I checked the front suspension again. everything's fine except the rear Strut rod to K Member bushings. The Bushing and rear washer can now rotate by hand. It isn’t tighten enough? Or it is a normal condition?
Thanks
Thanks
