the lower valance is plastic... did you paint that too?
I'm about to spray mine too when we get a day without too much humidity. Running around with a black car with a rear bumper with primer is not attractive. Did you use rattle can paint or spray gun for this? BTW, the lower valance is very easy to tape off. You might not want clear coat on it.
I just finished up wet sanding and buffing out the rest of the car. Don't know how comfortable you are with doing this, but it can really fix a lot of paint application issues. I suspect with the rattle cans you will get some inconsistencies with the final coat. You might want to consider sanding and buffing. The results are great.
hard to tell from that angle, but seems ok... FYI you'll want to wait a bit longer before buffing... most clears (even rattle cans) are something like 60 days for full cure.
