yes, a lot has.
I though the OEM size was 235/50R17 (at least that was what was on my car when I bough it) currently I am running a 245/45R17, but at one point I had a real sticky set of 255's on it. cant remember if it was by 45 or 40 though. it was recommended my an older member on here. car was/is at stock riding height and no issues with the wider ones.
I have run a couple sets of 255/45 R 17's. Good fit, no rubbing and look fantastic. Handling is improved with the wider tires with a tradeoff of a slight drop in gas mileage. Speedometer will read .9% lower so you are very close with reading speed.
Stock wheels are 7 1/2" wide.
...but 16s are 7.0 wide, ...
Service manual says 7.5"
http://deneau.info/ls/s6x~us~en~file=s6x44001.htm~gen~ref.htm
Ahhh..... My mistake. I forgot the 16" wheels were 7" wide.....
in all fairness, the OP was asking about 17s...
The tire calculators said my speedo would be off -2 mph at 70 but it is actually only -1 according to my GPS.
