I'll also add... you know how everyone in the sports world makes fun of the Corvette for still using a 2 valve pushrod engine?  Considering they're pushing close to 600HP with a smooth idle and decent mileage,
 I used to be in that same boat a few years ago, I couldn't stand push rod motors and chevys hanging on to such old school and old tech when there are so many improvements to dual cam motors. their biggest problems used to be they flowed too well and because of that they had very low low end torque due to the much slower air velocity, hence why ford used dues intake runners with a butterfly valve to keep one closed at low RPMs like my Mark had or when honda used VTech and started using variable timing (which btw, too bad ford waited so long to hop on that wagon!)
but then after seeing the engines side by side, you can see the benefits, especially after chevy started using aluminum blocks and heads, a 7.0 LS7/X motor is physically a lot smaller than a ford twin cam like the 4.6 & 5.4 (hell, I think its even smaller than our jag 3.9 or even the duratec 3.0.)
more so what makes them better in a car like a vette as opposed to motors of our design is where all the weight is... with such massive and wide heads like ours, that puts so much weight so high up raising the center of gravity, with only having one cam instead of four, and such smaller and lighter heads, the center of gravity is a lot lower in those motors which helps to lower the center of gravity in the car, there for making it handle better...
			can you imagine what they could get out of a multivalve overhead engine with the LSxs engine design?  Heh heh heh... I think they'd get so much power out of one that they'd have to completely redesign the car to keep it from twisting itself in half.
then you would just be talking about an over complicated large displacement northstar, and everybody knows how "awesome" those cars were! lol
i think chevy should just keep what they are doing, keep it simple with way fewer parts, load those top ends up with all sorts of titanium goodness, keep the displacement up, and then offer versions of them in everything you make from trucks, to family sedans, to muscle cars, to sport/track/race cars!
long story short, if its working well, keep it up!
also just for fun, compare the prices of a ecoboost v6, a coyote, and a LS3  that all can make in the same range of power power and tell me which price is the one you would want to pay!
