... It's specifically while in gear and not moving that you get a mildly rough idle. ...
Motor mount?
Motor mount?
Keep it coming, so far 100%. This might be the only and last coil any LS owner needs.
... On a side note, I have my plugs gapped to .039" rather than .044". Unknown how this might affect coil life.
Got that from NGK website.0.039" (1.0mm) is correct for the V8, 0.044" is just outside of the max tolerance (1.1mm). I'm sure it is a factor on coil life. Who said to use 0.044"?
Kumba was referring to his Accels which he modified to fit under the coil covers. He has a thread on it. Cut, bend, re-epoxy and he used the factory boots. As for myself, i like the look and the fact they will stay cooler with the covers off.
I have to say that the Motorcraft and the Visteon coils that I have in my LSes have been in for longer than anyone has mentioned for their Accels so far. I think that while they may end up being better, so far this thread has only shown that they aren't terrible.
