Hi everyone,
I want to install a M7 radio into the M8. This will give me the space needed above the radio to install the Asham 8 I just received, as well as a rocker switch for the park height, and on/off for the suspension itself. I would like to have it set up (going from bottom) as heated seats, hvac unit, radio then Asham 8 at the top.
I previously wired a line in into the M7 radio so I could use my android as my music player. It has a much better sound than a cassette adaptor I'm currently using in the M8.
My idea is to keep the stock look and add the Asham8 trying to maintain the stock dash look as much as possible. To be honest, I prefer a dial for bass and treble as it is in the M7 vs. electronic push buttons in the M8.
The main wiring connectors are the same, the second to the amp is not, and the pin locations are not the same. I can re&re the pins so the wires are in the correct location for the main harness, but the amp output will have to be cut or so I believe at this point.
Funny I have a brand new Alpine single din with line in and usb and still would prefer the M7 radio/deck.
Any assistance would be greatly appreciated, thanks.
