Keyless keypad works but will not light up
03LinLS
sc pa
I recently had a window regulator go bad in my '03 and had a body shop put it in. Just noticed tonight the keypad works but it won't light up. Not a big deal but I was wondering if it is a simple check/fix or should I just take it back to them and have them fix it? Thanks for the help.
I'm not too sure about illumination of the keypad, but it could be they snagged a connection when they installed it. I'd just take it back and have them look at it. Perhaps blew a fuse?
There's more than just the keypad LED illumination on that fuse. Either they broke a wire, or the knocked one of the LEDs off the PCB of the keypad.
Thank you. I will probably leave well enough alone since it does work and rarely use it anyway. Thanks again.
