RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,734
- Reaction score
- 523
Not 100% sure on that, sorry.
Upper control arms for the rear when ordered for a Lincoln LS may arrive with the word JAGUAR stamped on it, least one out of the two of mine did.
http://www.tascaparts.com/auto-parts/2000/lincoln/ls/base-trim/3-9l-v8-gas-engine
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1373903 << MOOG rear Stabilizer Bar End Linkages currently on sale
MOOG Part # K80246 & K80245
DEEZA Part # JAL607 Toe adjust link (note: no passive steering though)
more: http://www.lincolnvscadillac.com/fo...-Parts&p=2037316941&viewfull=1#post2037316941
1st GEN LS
Should stay away from the Energy Suspension sway bar bushings, they are too narrow for the bracket and slide side to side.
there is too much play on these. Member Hite337 put me onto Rein XR819697, I also confirmed the ES bushings move about.
http://www.fcpeuro.com/products/jaguar-suspension-stabilizer-bar-mount-xr819697
You'll need to order qty 2 as the shopping cart misleads you to think qty 1 is a set, which it is not.
Use the old OEM bushing brackets, clean them up and use the Jag bushings. They are a direct fit on the 1st GEN LS.
Removed the Universal Energy Suspension bracket and bushings as they are not a good fit.
Replaced with original brackets and REIN Jaguar bushings.
Fits like OEM. Bolt near the DCCV was a PITA again!
